oil seeping
Old Aug 31, 2009 | 09:29 PM
tjthegreat's Avatar
tjthegreat
oil seeping
hey guys the 351 in my van has oil seeping from the the oil pan and the head gaskets, i looked at my oil and its right at the bottom of the cross hatching after around 3k miles so i aint to worried about it ,but i was just wondering if u guys knew any easy solutions to fixing the problem,thx
Old Aug 31, 2009 | 09:35 PM
bashby's Avatar
bashby
Add 1 qt of oil
Old Sep 6, 2009 | 10:25 AM
tjthegreat's Avatar
tjthegreat
i know it just leaks on to the exhaust an makes an annoying smell,but im just gonna replace the gaskets
Old Sep 6, 2009 | 10:28 AM
MisterCMK's Avatar
MisterCMK
Are you sure it is leaking from the head gasket? I've got a leak on my Mustang that was the valve cover gaskets and it still leaked. I did some more poking around and it turns out the leak is coming from the back of the intake manifold where it meets the block. Apparently I didn't seal it up well enough when I did my cam swap. Point is, make sure you clean everything up and see where the leak is actually coming from and not what it is leaking down onto.
