Front axle
Old Aug 31, 2009 | 06:56 PM
snowbrdjnky's Avatar
snowbrdjnky
Front axle
I have a 1978 F150 4x4 with i believe the original front axle. I do not know which one it is. How can i tell what it is with no tag? Any help would be appriciated.
Old Aug 31, 2009 | 09:10 PM
Dads79's Avatar
Dads79
Should be Dana 44. All half tons and Bronco's in 78 came with them.
Old Aug 31, 2009 | 09:52 PM
shanes66charger's Avatar
shanes66charger
I admittedly don't know as much as some here, but unless it was changed by a PO, It is likely a dana 44 with 3.50 gears.
Old Aug 31, 2009 | 09:57 PM
snowbrdjnky
Thanks
You guys are great. Thanks alot. I was leaning toward the Dana 44 but i wanted to be sure before buying the parts. Also, one more thing. Does anyone have any idea why my axle U joints are pressed together, instead of the usual interchangable U joint?
Old Aug 31, 2009 | 10:01 PM
75F350's Avatar
75F350
Are you asking about your axle u-joints? They are not pressed together, they simply do not have external c-clips. Instead they have internal c-clips. Look to the inside, or back side of the u-joint cap, on the under side of the u joint itself, and you will find some c-clips that have to be removed in order to take the caps off.
Then you can press them out with a u-joint press like normal.
