Sponsored by: Real Truck
darn doors
Old Aug 31, 2009 | 01:54 PM
cole60's Avatar
cole60
darn doors
Hello i have used wd40 on the latch to get the door ajar light to go out. Still on and now the power locks on that door are not working, you hear the latcvh trying to click but it will not, you can lock and unlock manually and it moves free and smoth.. So what do you guys think. thanks
Old Aug 31, 2009 | 02:28 PM
Wagion's Avatar
Wagion
Sounds like the little actuator motor for the lock in the door is going bad there is a fix on here about them if you want to do it with out replacing the motor. FYI it is better to use something like white lithium spray grease on your doors as it stays on longer than WD. It is sold in a can and had a steel ball in it like spray paint and most come with the little straw you can use to shoot it into the latch. Never use anything but dry graphite powder in the lock itself.
