aurora 3000
Old Aug 30, 2009 | 10:02 PM
blueovalbigblock's Avatar
blueovalbigblock
aurora 3000
does anybody know how much boost a Aurora 3000 with a wicked wheel is capable of on a 2004 6.0?? also how much boost ccan the stock heads/studs handle?
Old Aug 31, 2009 | 05:57 AM
npccpartsman's Avatar
npccpartsman
Wicked wheel is a 7.3 thing. As far as boost goes it's a toss up. I've seen them puke at 28. I've seen them hold at 35. It depends on what condition they're in to start with.
Old Aug 31, 2009 | 06:15 AM
tex25025's Avatar
tex25025
Another thing is that the Aurora 3000 actually does better for the Dodges then it does for the Fords. I know of only 2 people that have used it and they weren't totally happy with it.
Old Aug 31, 2009 | 04:06 PM
blueovalbigblock
thanks guys! one more thing.. do you have to lift the cab to get to the turbo on a 03/04 or is that only on 05 and newer?
Old Aug 31, 2009 | 04:20 PM
adambomb's Avatar
adambomb
to answer both your questions no and no. lifting the cab or pulling the engine is for bigger stuff like Head Gaskets, and Internals. The turbo sits near the top, i hear it takes a couple hours to remove especially if it's your first time and you don't have all the tools layed out.
Old Aug 31, 2009 | 05:08 PM
npccpartsman
No cab lifting required for turbos. To make it MUCH easier take the degas bottle loose (two bolts-8mm wrench) THEN take the wiring harness that runs across the top of the firewall where the hood seals---round plastic clips/christmas trees, then all the associated plumbing. 03's and 04's before 9/29/03 have a different turbo bolt location than later 04's. You will need an 11mm deep socket or 7/16 deep socket, 10mm socket and/or 10 mm flexhead ratchet wrench, and some extensions to get it off. Takes about 30 minutes or less with a little practice. Right side CAC tube comes off and air intake comes off. Turn the turbo on it's side and twist it out. NOTICE where the turbo oil drain is. it goes back in first
Old Aug 31, 2009 | 05:27 PM
Maxium4x4's Avatar
Maxium4x4
30 minutes? Took me that long to decide where to place a grenade.
I use a stand at the front of truck with a moving company blanket to keep from being impaled by a few objects.
Old Aug 31, 2009 | 06:58 PM
william_04_x's Avatar
william_04_x
It'll make the decision process easier if you have a big box of them..
