Sponsored by: Real Truck
Cruise Control
Old Aug 30, 2009 | 08:32 PM
shs-pictureman's Avatar
shs-pictureman
Cruise Control
I have a 2002 F250 SD 4x4 5.4. I just replaced the pressure sensor on the master cylinder and the cruise started to work again. I just bought the truck, so I don't really know how long it hadn't worked. I noticed a small noise when I press the set button to engage it and when I tap the brake to disengage it. I was wondering if the was some sort of solenoid or some moving part that is making this noise.
Old Aug 31, 2009 | 10:44 PM
Meeks's Avatar
Meeks
Where do you think the noise is coming from? under dash, steering wheel??
Old Sep 1, 2009 | 06:58 AM
shs-pictureman
I think it is coming from somewhere in the engine compartment or maybe the transmission. It doesn't sound like it is coming from under the dash or inside the truck. The sound is like a very soft horn or a soft squeal.
Old Sep 1, 2009 | 07:36 PM
nghtrgr's Avatar
nghtrgr
Originally Posted by shs-pictureman
I just replaced the pressure sensor on the master cylinder .
Is this a messy process??? How much is the pressure sensor?? Thx
Old Sep 1, 2009 | 08:24 PM
shs-pictureman
It's not very messy at all. A little bit fluid comes out when you remove the sensor, but a rag under the sensor catches it all. Just have the new one ready to screw back in. I paid $28.00 for the sensor.
