power steering
Old Dec 18, 1999 | 09:58 AM
jonjamky's Avatar
jonjamky
power steering
When turning the steering wheel there is a rubbing sound coming from the front end .Sounds like it is coming from the steering box,any ideas what is causing this? This is on a 1997 Expedition.Thanks for any help.
Old Dec 8, 2000 | 03:03 PM
sullivanmar's Avatar
sullivanmar
power steering
My 98 Expedition just (within the past month) started exhibiting the same symptoms. Anyone else?
Mark
Old Dec 8, 2000 | 06:44 PM
jonjamky's Avatar
jonjamky
power steering
The rubbing sound is the pitman arm.I had to have mine replaced on my 97 Expedition. That solved the problem.It was covered by the warranty
Old Nov 24, 2002 | 12:14 AM
simonbolivar's Avatar
simonbolivar
power steering
Go to any autopart supply and buy a needle fitting for your grease gun and inject some grease through the rubber boots on the tie rods.
That will cure the problem and buy you some time if your warranty period has expired.
Old Nov 24, 2002 | 06:33 AM
1999XLT's Avatar
1999XLT
power steering
