exhaust question
Old Aug 30, 2009 | 04:58 PM
struttin's Avatar
struttin
exhaust question
does anybody know if there is a crush washer between the turbo and the exhaust inlet pipe . ive got a lot of leakage there and the clamp is as tight as i can get it.
Old Aug 31, 2009 | 08:04 AM
l-m tech's Avatar
l-m tech
sounds like you need to clean the rust out from between the turbo and exhaust pipe.
Old Aug 31, 2009 | 12:55 PM
npccpartsman's Avatar
npccpartsman
And besides cleaning the rust, if you've replaced the turbo then it's not a bad idea to loosen the y-pipe at the exhaust manifolds and EGR cooler if it's there and tighten the inlet to the turbo first. I have to do mine this way every time I remove my turbo or I'll get a leak. The exhaust manifolds are, for whatever reason, a little more forgiving on sealing off.
Old Sep 1, 2009 | 07:54 AM
l-m tech's Avatar
l-m tech
guess i should of asked if you had a leak at the inlet of the turbo or the outlet of the turbo.like stated above its kind of a pain to get the y pipe to line up with the inlet odf the turbo.i was just assuming you ment the inlet of the down tube on the exhaust.
