A.I.R. Pump
Old Aug 30, 2009 | 01:56 PM
TheWingnut's Avatar
TheWingnut
A.I.R. Pump
My pump is making a loud whinning noise so I think I am going to replace it, should I replace the bypass valve and check valve as well?
ja
Old Aug 30, 2009 | 11:23 PM
Franklin2's Avatar
Franklin2
I would make sure the check valve is working. If it lets exhaust up into the pump, that's what will ruin them over time.
Old Aug 31, 2009 | 09:34 AM
TheWingnut's Avatar
TheWingnut
Well I replaced the AIR pump but the noise did not go away. It is from that side of the engine. The Alt and Starter have been replaced, but the high pitch whinning is still going on. The noise is in conjuction with the reving the engine. There is nothing over there except the exhaust manifold and shroud and tube assembly, but that is where the noise is coming from.
Any idea's?
Old Aug 31, 2009 | 01:42 PM
muleguitar's Avatar
muleguitar
have you gotten underneath your truck and listened for it?
Old Aug 31, 2009 | 02:23 PM
TheWingnut's Avatar
TheWingnut
bad Altenator, second one in two years, bearing were worn out, must have over tightened it last time.
