Need help here! BAD!!!
If I pull a plug it is soaked. The spark also looks alittle weak on that cylinder. So I am thinking, somthing to do with the injector?? Distributor (I tried a spare and the samething)?? or ???
PLEASE HELP! I am going insane here
When you say that 2 header tubes stay wet did you mean the 2 inside tube on the same bank? Also when you said your plugs were wet do you mean these same 2 cylinders? If yes, and you have already changed the obvious stuff you might consider running a compression test. You may have blown a head gasket. It would have to be blown pretty bad to display your symptoms. I don't know alot about your model year,.... you say it is fuel injected. I take it that you have multi-point injection i.e. one injector per cylinder? If so (I don't know) can you swap injectors with other working cylinders to see if the problem moves to the new one's location? Like I said I don't know alot about new stuff. Good luck and post your results.
Lee
