Trouble removing Spindle?
Old Oct 11, 2009 | 07:44 AM
Diesel_Brad's Avatar
Diesel_Brad
Have you sprayed it real good w penatrating fluid?
Old Oct 11, 2009 | 10:28 AM
Varkwso's Avatar
Varkwso
Soaked it with PB Blast for two days. It was definitely rust welded on.
Hit with a propane torch (no effect).
I put the nuts back on - but I think it would have been fine without them!
Old Oct 11, 2009 | 11:05 AM
Otto Square's Avatar
Otto Square
When using a propane torch, the hottest part of the flame is at the tip of the inner blue flame. If you hold this part of the flame just in contact with the part, you can get some red color in the metal. (It does take a lot of time. Oxy/Acetylene is WAY hotter.)
After that, try quenching it with water and heating it again. The expansion/contraction should break the corrosion free eventually. Probably still have to hit with a hammer, though.
Old Oct 12, 2009 | 12:56 PM
Varkwso's Avatar
Varkwso
Do not currently have a oxy/acetylene - but avoided getting out the plasma cutter. Patience is not always my strong suit...
The 1996 F250 4X4 is with the new owner now - with the 460 it is a towing maniac. The previous owner wanted it back badly so I sent her way with the new balljoint in the passenger seat and the old cracked rotor filling another pothole in the driveway...
vortec 1
Nov 28, 2018 10:44 AM
snoball1974
Feb 10, 2017 08:11 AM
FuzzFace2
Feb 6, 2016 09:28 AM
FuzzFace2
Feb 1, 2016 11:06 AM
Craig46
1947 and Older Ford Trucks
35
Dec 19, 2015 02:16 PM
