Sponsored by: Real Truck
speedometer and cruise control problems
Old Aug 28, 2009 | 11:53 AM
mduvalsr's Avatar
mduvalsr
I have a 1999 ford f350 dually with 7.3 diesel. Sometimes when I start up and drive the speedometer will read nothing, the od light flashes on the gearshift and the cruise control does not work. sometimes stopping and turning off the engine and restarting the engine the problem goes away. Several people on the forum have suggested getting the codes when this happens but the all codes show normal. Some have suggested the sensor on the differential and on the transmission may be bad but wouldn't the code scanner pick that up when jt goes bad especially when I have the scanner going when it goes bad. Any help would be appreciated
