starting problems!!
Old Sep 4, 2009 | 11:45 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I see your location as Thornton - is that Thornton, CO? If you can clarify or even better, add the state to that, it'd be helpful.
I just had a bunch of starter issues myself, but let me clarify your symptoms, and please correct any that aren't accurate:
Power to all accessories (lights, radio, etc.) is fine
Truck starts 90% of the time with no problem.
New batteries, alternator, GPR, and starter. (What brand and store did you get these from?)
Fuel filter, fuel lines, and air filter are fine.
So when the truck will not start, the only thing that happens is a "CLICK" from the general area of the starter, correct? Repeated tries will eventually get the engine to crank and then fire.
Questions:
1. When the truck cranks over, does it ever fail to start?
2. Have you ever had the opportunity to have someone get under the truck and try to locate the source of the "CLICK" when it does fail to crank?
My vote would be for a failing starter solenoid, which as was already pointed out, is integral on the starter itself, not on the fender well. I eventually went with an OEM Mitsubishi starter for my 1999 7.3 and have had zero issues with it since. My source was Nations Starter & Alternator (WEBSITE) and paid $175 shipped for a 100% brand new starter. Your 2002 will be slightly different but check their site and/or call them.
It would be a very good idea to check your battery cables for current & resistance. Corrosion happens internally sometimes, so you never see it, but the cables turn out to be junked.
You're not too far from J&B Auto Crush either. You might try there for a wrecked 7.3 for a starter or battery cables. They're at 4980 Brighton Blvd. Ask for Mike, he's incredibly helpful and a great guy.
Old Sep 7, 2009 | 01:13 PM
BWPowersmoker02's Avatar
BWPowersmoker02
Thornton CO is correct...The clicking comes directly from the starter itself. Once the truck cranks over it never fails to start, the only problem is getting it to crank...I replaced the solenoid today and so far no problems since. I also used the OEM part and i think, at least i'm hoping that all problems are solved!! I appreciate everything you guys have done! its helped!! If this doesn't work i'll let you guys know but cross your fingers! haha i will check the cables just to be safe for internal corrosion. I'll let you guys know
TheNamesTopher
Dec 13, 2020 10:00 PM
ExPACamper
49
Mar 31, 2015 03:52 PM
Roddy's Dad
Jan 9, 2015 07:37 AM
DallasSuperCrew
2004 - 2008 F150
Jan 12, 2014 02:02 PM
