Code P1507
Old Aug 27, 2009 | 07:36 PM
lv2race's Avatar
lv2race
Code P1507
1st time the Expo threw a code, P1507, Idle Air Control under speed error. The wife said it was hesitating, I didn't drive it but ran the codes. I've read that cleaning the IAC helps big time, so that is what I'll do first. Anything else that I need to do?
Thanks,
John
Old Sep 1, 2009 | 09:08 AM
99ExpyProblems's Avatar
99ExpyProblems
Does it stall when idling? Mine got really rough and I cleaned it and hasn't caused a problem in 30,000 miles. Some don't get that lucky!
You can check the IAC solenoid resistance. I believe it is supposed to be about 10 ohms. You can also disconnect the IAC valve while the engine is running, iff there is no change in rpms, you have a stuck or damaged valve. You can try cleaning it along with the throttle body and see if that helps.
Old Sep 1, 2009 | 11:20 AM
lv2race's Avatar
lv2race
My wife said it wanted to stall but it didn't, then getting on the freeway or taking off from a light, it had no power and didn't want to take off like it normally would.
I removed the IAC and cleaned it with throttle body cleaner. It had alot of carbon build up, and the flakes and carbon pieces were coming out as I was spraying/soaking it. I also cleaned the throttle body then changed the oil and filter. Disconnected the negative cable to reset the computer, took it for a drive and couldn't get it to act up. The wifey said it worked fine yesterday too, so I hope my issues are over.
Old Sep 1, 2009 | 07:30 PM
99ExpyProblems
Awesome, hope it works!
Old Sep 1, 2009 | 08:16 PM
lv2race's Avatar
lv2race
Me too! If anything changes for the worse, I'll post symptoms.
Thanks
Old Sep 3, 2009 | 09:09 PM
lv2race's Avatar
lv2race
It works! Passed CA smog today with 0 emissions and the car gets up and goes like it's supposed to do. No more rough running or stalling issues either. It's amazing what a clean IAC will do for you.
Old Sep 4, 2009 | 12:54 PM
99ExpyProblems
FYI, it is always fun for me to know when I've saved myself $300 (dealer charge) for about 1 hour of my time and a few dollars in Cleaner! Great, glad you could get it fixed.
Enjoy.
CoolitKen
Feb 15, 2018 06:56 PM
roller24
Mar 21, 2017 12:55 PM
Lightning23
46
Jan 5, 2017 07:58 PM
78F2504x4
3.8 & 4.2L V6
Mar 8, 2011 11:18 PM
kilted_drummer
Escape & Escape Hybrid
Jan 15, 2009 01:07 PM
