T.C. lock switch w/pics
Old Aug 27, 2009 | 06:10 PM
Brown Falcon's Avatar
Brown Falcon
Safety Switch in the dash:
Red wire from switch to transmission wiring:
Splice into PURPLE wire w/ YELLOW stripe:
The other wire from the switch goes to Ground. THere are two purple wires on the transmission bundle. One is purple w/ red stripe, other is purple w/ yellow stripe. You want the purple and yellow.
This is a manual switch so you must turn it off to unlock the converter. I recommend unlocking it under 20mph and ALWAYS when you come to a stop or you will kill the motor or just roll through the brakes.
When used it will keep trans temps down quite a bit. Also helps you engine brake better.
Old Aug 27, 2009 | 06:43 PM
Cuda_jim's Avatar
Cuda_jim
I read somewhere that you shouldn't allow the engine RPM to go below 1300 with the TC locked. Something about the trans pump not producing enough pressure to hold the clutches from slipping. That's more of question than a statement...I want to do this mod too.
Old Aug 27, 2009 | 06:49 PM
Brown Falcon
That could be true. What I know is that the expensive kits you can buy for this are set up to unlock the trans below 25mph.
So that's basically what I go by.
Old Aug 27, 2009 | 06:58 PM
Cuda_jim's Avatar
Cuda_jim
Yep, you are right. Just found it. Scroll to the bottom of the page for the Disclaimer paragraph. This shows the mod for a 1999+....same thing only different
http://forgotton.net/mods/tclock/index.htm
Old Aug 27, 2009 | 07:00 PM
TheTowingCowboy's Avatar
TheTowingCowboy
I personally can't wait to do this, hope to get it done tomorrow or saturday so I can try it on my sunday drive to church... god bless the diesels =D
Old Aug 27, 2009 | 07:03 PM
427 fordman's Avatar
427 fordman
I'm not real familiar with this but was wondering when do you use it? When towing? Just curious cause I tow a lot and am making a list and gathering parts for a multi-project on my truck this winter and wonder if this is something I should do. Thanks
Old Aug 27, 2009 | 08:58 PM
joe_13894's Avatar
joe_13894
Don't ever use these connectors on a vehicle, particularly underneath:
They WILL fail on you. I can't count the number of repairs I've done because of those connectors.
What's worse, they let water into the wire and it wicks along the strands and corrodes the whole wire.
Since the early 90's, vehicle manufacturers have gone to sealed connectors and the reliability of electrical systems have improved immensely. At a minimum, seal up the splices with liquid electrical tape. Better yet, get the sealing heat shrink found at many auto parts stores and seal them up tight like Ford does from the factory. You'll be happier in the long run.
Old Aug 27, 2009 | 09:19 PM
pjwoolw's Avatar
pjwoolw
Friends don't let friends use scotch locks.
Old Aug 28, 2009 | 12:08 AM
95psd's Avatar
95psd
You should see the connectors on our engine harnesses at Western Star. They are built in Mexico and they must not have heat shrink down there. The terminals look look like the ones you would buy at an auto parts store if you were building it in your garage not on a new oem shop.
Old Aug 28, 2009 | 06:57 AM
Brown Falcon
Just so you know these pictures are from the install the previous owner did on this mod. I didn't put it on there.
Just had a lot of questions on how to do the mod so I crawled under the truck and took pics.
It is great for towing, especially when going uphill at speeds lower than the TC usually locks (below 45 or so) and will keep your transmission temps cooler. Also lets you use the engine to brake on downhill so you don't use your service brakes as much.
Old Aug 28, 2009 | 01:00 PM
Talyn's Avatar
Talyn
Man, I want to do this mod.
Oh wait, I just let the clutch out and my TC locks.
hahaha.
Old Aug 28, 2009 | 01:09 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Squirt some silicone inside those connectors before you crimp them. Works great.
Personally I like the 'T' taps, same kind of design, but the intruding wire gets connected via a blade terminal and is removable without disrupting the crimp/connection in the original wire.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 28, 2009 | 01:28 PM
Brown Falcon
hahaha.
You have no idea how jealous I am of you... I want a 5 speed SO BAD!
Old Aug 28, 2009 | 02:15 PM
Pest007's Avatar
Pest007
Doesn't "the cure" also address this, or am I thinking of something else?
Old Aug 28, 2009 | 02:30 PM
Talyn's Avatar
Talyn
The cure has something to do with shifting. but I belive it also addresses some TC issues.
But then again, I don't exactly remember what Tim told me it does.
