Rims + Salt =
Old Aug 27, 2009 | 02:21 PM
7.3 Rocket's Avatar
7.3 Rocket
Rims + Salt =
So there is a picture of the damage that salt will do to stock XLT rims. The clearcoat is bubbled and I can peel some off with my fingers.
I'm thinking that I can strip the clear off them and polish them up. Either way they won't get any worse.
The question is this: What would you use to get the old clearcoat off them? My brother suggested sandblasting them, but I'm not sure if it'd screw up the rims themselves.
Old Aug 27, 2009 | 03:42 PM
1Aauto's Avatar
1Aauto
Former Vendor
HI Pete,
Here's a link to a pretty cool tech tip I found on how to restore a wheel link this.
http://www.flashoffroad.com/features...on_wheels.html
Old Aug 27, 2009 | 03:47 PM
7.3 Rocket's Avatar
7.3 Rocket
Thanks, Tony. Reps to you on that one.
Old Aug 27, 2009 | 03:49 PM
shark1979's Avatar
shark1979
it is going to take a lot of work to pol;sih those rims. i tried it on another truck i had. IMO you should just save up and get a new set. to polish right you will need a clay bar of different grits and a small power buffer, and then some good metal polish. speedy polish is what the trucker guys use around here on there rims and fuel tanks(works real good) as far as getting the clear coat off. you could try a good wheel acid,or go to a body shop and get there paint remover. sandblasting with some superfine sand would work but might leave some pits not sure never done that to any rims.
Old Aug 27, 2009 | 03:50 PM
1Aauto's Avatar
1Aauto
Former Vendor
Thanks man.I'm thinking about trying it on my 04 Jeep Cherokee wheels. I live up here in New England and they're all pitting right where the wheel weights were.
I clean these wheels all the time too even in the winter,nothing stops the stuff.
Old Aug 27, 2009 | 03:52 PM
1Aauto's Avatar
1Aauto
Former Vendor
Josh read that link it's pretty good. I'm going to try that corn startch trick on my Weld wheels on the stang.
Old Aug 27, 2009 | 03:57 PM
shark1979's Avatar
shark1979
i will have to try that trick, i have never had any luck with polished rims. always had bad spots or got real dirty real fast, mainly brake dust pitting them. thats why i went with a black rim the last time i got rims!!
Old Aug 27, 2009 | 04:03 PM
7.3 Rocket's Avatar
7.3 Rocket
My thoughts are this:
Try to polish them and if they come out good use them year-round.
If they come out crappy I'll save up for a new set of rims and tires but save the old ones for use during winter. First snowstorm to after a few rains once they've stopped salting.
1Aauto's Avatar
1Aauto
Former Vendor
With polished wheels, I'd always wash the whole car first with car wash soap. Rinse it off, then I'd empty the bucket and take another sponge and pour in some liquid dish soap.
The car wash soap has waxes built into it that tend to haze the wheels over,so by using the dish soap only on the wheels,it would help to keeep them clean and strip of any wax of impurities.
You don't want to use it on the main body of the car because it'll strip the wax off.
The mother's mini polishing ball works good too.
Old Aug 30, 2009 | 01:54 AM
spdmpo's Avatar
spdmpo
Dang, that looks like a neat trick. I've got nothing to lose. I was going to find some new wheels but just taking off the clear coat might work. My wheels aren't corroded, the clearcoat is just peeling off. Might save me some $ and trouble.
Old Aug 30, 2009 | 04:56 PM
jdecker88's Avatar
jdecker88
I would find a good deal on some Lariat wheels if you can spare the change oneday but I know its tight. Tony thats a pretty good idea I need to do that on my smoked out wheels.
Old Aug 30, 2009 | 05:15 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
well since im a powdercoating freak i am going to suggest getting them sandbalsted then PC'd. then you can get whatever color you want. my guy even has a "chrome" color thats actually pretty good but the powder will hold up real well against all the road grime and salty stuff............
Old Aug 30, 2009 | 06:34 PM
trackspeeder's Avatar
trackspeeder
It will take some elbow grease to clean up those rims. It can be done. A good paint stripper is your friend. After the clear coat is stipped. Some wet sanding of the bad spots. I start with 600 grit and finish with some 1200 grit.
Now the fun stuff. Polish. keep polishing until it looks like a mirror.
The only problem is that with no clear coat the wheels will go to hell quickly in the winter. You might want to use a different set of wheels for winter use.
Old Aug 30, 2009 | 06:40 PM
allis327's Avatar
allis327
I sandblasted mine and painted them black. I like them my ex didn't but she still took the truck good thing it was a gasser.
Old Aug 31, 2009 | 12:08 AM
turboboost's Avatar
turboboost
look on ebay, i have found many sets of XLT rims for around $100 for a set with caps.
That are in real good shape.
