Arkansas Chapter Join Chapter Leader: Kramercd
Possible ABS Problem
Old 08-24-2009, 07:24 PM
Deven Mays's Avatar
Deven Mays
Deven Mays is offline
Trailering
Thought I would ask my local chapter boys first. The other day my 2000 Expy's brakes started grinding and before I got home the ABS light on. when I parked it and shut it off a fan like sound stays running. I have to disconnect the battery to make it stop. Any Ideas what it might be?
thanks
deven
Old 08-27-2009, 05:38 AM
cookie88's Avatar
cookie88
cookie88 is offline
Most likely separate issues. My Navigator did the exact same thing with the fan once. Originally thought maybe something got wet and shorted, but it turned out to be a low voltage issue of some kind. Replaced the battery and it's never done it since.
The brakes....well, if they're worn down so far that they are grinding metal I'd say the caliper pistons are over extended and you're losing fluid pressure.
Deven Mays
06-05-2011 11:27 AM
1Aauto
New England Region
07-21-2010 12:29 PM
SUPERDUTY OUTLAW
02-26-2009 12:23 AM
Deven L. Mays
04-05-2004 05:35 PM
mandad
08-07-2002 12:44 AM
Quick Reply: Possible ABS Problem
