carb change
Old Aug 6, 2002 | 11:34 AM
supercab4x4's Avatar
supercab4x4
carb change
i tried to change the carb on my 78 460 but it didnt seem to run very good so i changed it back.now it runs ok but seems to miss.could the other one have fouled the plugs out.i wish i didnt mess with it because it ran great.the one i tried to put on was a edelbrock from my 390.does anybody have any ideas. thanks for the replies
Old Aug 6, 2002 | 02:40 PM
Vampiro's Avatar
Vampiro
carb change
try changing the feul filetr and resetting the carbs mixture and idle speeds. also try the plugs wires, dist. and rotar. pretty much give it a tune up. but first tinker with the carb
Old Aug 6, 2002 | 06:20 PM
TorqueKing's Avatar
TorqueKing
carb change
When Vamp. says to reset the idle mixture and speed, reference the link below for a step-by-step on how to do this, if you're unfamiliar with Edelbrock carbs.
https://www.ford-trucks.com/dcforum/DCForumID76/135.html
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Aug 6, 2002 | 11:42 PM
supercab4x4
carb change
[updated:LAST EDITED ON 07-Aug-02 AT 00:48 AM (EST)]i put the original back on.the fuel filter is clear.the edelbrock had sat for awhile so im guessing it needs rebuilt.its the original that im having trouble with now.all lines are exactly as i had them before.i tried the starting fluid trick no leaks.should i get new gaskets anyway? when i had the edelbrock on gas was coming from everywhere thats why i took it off. all the plugs were new.also does anybody know where to get seafoam and is it ok to dip your carb into cleaner even if you are not rebuilding it?
Old Aug 7, 2002 | 12:40 AM
rebocardo's Avatar
rebocardo
carb change
Mister_King
Oct 27, 2014 12:40 PM
williamwilliam
27
Apr 13, 2012 08:49 PM
4x41977
Sep 6, 2008 09:12 PM
jowilker
25
May 3, 2005 11:44 AM
matt77F2504x4
Jul 27, 2004 07:47 PM
