Converting to MAF
Old Aug 27, 2009 | 07:53 AM
Khyren's Avatar
Khyren
Converting to MAF
I found a 96 I6 auto at the u-pull and was wondering just how much of the engine harness would I need for the conversion? I can re-pin the one I have for the new sensor no problem. But will the auto tranny comp work in my manual truck? Mine's a 95 so the issue with the smaller injectors with higher pressure isn't a problem.
Old Aug 27, 2009 | 08:17 AM
Conanski's Avatar
Conanski
You can use portions of the '96 harness for the conversion but the computer is no good to you since it is OBD-2 and uses a 104 pin connector versus the 60-pin OBD-1 system in your '95.
Old Aug 27, 2009 | 09:08 AM
Khyren's Avatar
Khyren
OH yeah, I forgot aboot that... What a pain in the ***
Old Aug 27, 2009 | 06:49 PM
c_rossman's Avatar
c_rossman
Has anyone ever thought about using a MAF setup from a early 90's Taurus 3.0? Maybe have to get a tuner but parts are everywhere. I would like to try some things on my 300-6 to get a little better fuel mileage.
Old Aug 27, 2009 | 07:06 PM
c_rossman's Avatar
c_rossman
[QUOTE=c_rossman;7874912]Has anyone ever thought about using a MAF setup from a early 90's Taurus 3.0 or 3.8L would maybe be better? Maybe have to get a tuner but parts are everywhere. I would like to try some things on my 300-6 to get a little better fuel mileage.
Old Aug 27, 2009 | 10:13 PM
Conanski's Avatar
Conanski
You have a C6 tranny, the single best thing you could do is install a tranny with OD, the AOD and both Mazda and ZF 5 speed manuals would provide this.
