Cracked frame around steering box?
Old Aug 26, 2009 | 09:24 PM
bozzchem22's Avatar
bozzchem22
I don't post here often since I use my truck for trips to Home Depot, the dump, etc.
I've done a few searches but may have used the wrong terms since I didn't find the answers I was looking for.
My problem? I have an '88 F-150 4x4 longbed XLT Lariat that just failed my NC inspection today. I was told there was a crack in the frame by my steering box and that the body would have to be removed so they could get to the frame to fix it. My BS meter went off so told them just stop and I'd pick it up. I recently paid $800 to have a rebuilt transfer case put in so don't really want to keep throwing money at the truck considering how little it is used but have enough tied into it that I don't just want to scrap it.
I talked to a buddy of mine who owns a Chev and he told me this was a known issue with older Fords and should only require removing the inner part of the fender (rather than the whole front end) and could be welded without too much work.
Too bad he lives 70 miles away or I'd just drive it over and let him do it. Then again, that may be my best option...hoping I don't get pulled for an expired tag.
I don't have a welder and really need to get it inspected so I can get my tags renewed. I don't have pics of the crack but can certainly post some Friday after the shop shows it to me. Without the pic, I'm just throwing this out as a "what if" kind of question to all of you gurus who know these trucks like the back of your hand.
Is this a "known" issue and can it be repaired for a reasonable cost?
Thanks!
Old Aug 27, 2009 | 02:19 AM
Sycostang67's Avatar
Sycostang67
It is somewhat common on fords. It's usually a result of worn components and larger tires. I had a 79 F-150 with a crack in the frame by the steering box. I took it to a frame shop and it only cost $125 to get it fixed. They drill a hole in each end of the crack to stop it from spreading and then weld it up.
Dave R.
Electrical Systems/Wiring
13
Aug 22, 2021 08:39 AM
Sous
277
Jul 12, 2017 08:12 AM
Oldanvilyoungsmith
May 20, 2017 11:03 AM
BigSix1
Aug 23, 2014 11:14 AM
Jack Hammer
Sep 27, 2013 05:52 PM
