Sponsored by: Real Truck
Need Techie Help for Power Steering
Old Aug 25, 2009 | 11:12 PM
Jim McCarty's Avatar
Jim McCarty
My F350 has been in the shop since last Thursday because they can’t find a leak in the power steering system. Most of the time, there is not so much as a drop of fluid on the ground. Then, generally when it is first started, it dumps a puddle about 12” in diameter until I can shut it off. When I restart, not a leak.
It may leak the very next time I start it or not a drop for a few hundred miles and numerous starts. The truck is covered with power steering fluid from the reservoir to the suspension so it is hard to detect exactly where it originated. When it does leak, it is under pressure and not just dripping. It makes the puddle in the time it takes me to shut it off.
I’m baffled – and so is the diesel tech.
Old Aug 25, 2009 | 11:35 PM
ameinig's Avatar
ameinig
Man, can't they get some dye in that thing and hit it with a black light? If it is leaking that bad they should be able to see where the dye starts from.
Old Aug 25, 2009 | 11:40 PM
Jim McCarty
They can't get it to leak. That's what is frustrating. It is a gush or absolutely nothing.
Old Aug 25, 2009 | 11:47 PM
ameinig's Avatar
ameinig
The dye should still show. It shows up bright under the black light so you can usually see where it is originating from.
Old Aug 25, 2009 | 11:53 PM
EXv10's Avatar
EXv10
Sounds like you need a new mechanic. That has got to be an obvious fix. Something opening up under pressure probably. Clean it all up good and then wrap potential areas with rags and strings to narrow if down.
Old Aug 26, 2009 | 01:58 PM
Wagion's Avatar
Wagion
Does the position of your tires have anything to do with it. Have you noticed when it leaks if your tires are cut hard to right or left?
Is pump starting to go bad and blowing it out every once in a while?
I have no idea but is there an inline filter on that year? (I had one on my 96 Bronco it was after market had all kinds of problem till I found it (inside hose) and removed it.)
Old Aug 26, 2009 | 02:01 PM
Wagion's Avatar
Wagion
+1 vote for the clean it up with degreaser really good top off the fluid with dye and try to make it leak turn steering to stops both ways and hold it for a minute. Drive over some bumps. Drive in tight circle in both directions both forward and reverse.
If it is coming out under pressure it has to be from the pump or the high pressure line.
Old Aug 26, 2009 | 03:16 PM
sdetweil's Avatar
sdetweil
while not on this kind of truck, I suddenly got PS fluid all over on my hotrod.
yesterday it was ok, today not..
somehow the high pressure hose had come loose at the pump. didn't LOOK loose,
and wasn't dripping. I hadn't touched it in over 1.5 yrs since I assembled the engine onto the chassis.
I agree, if its coming out under pressure, its gotta be the hose, or a blown gasket.
holding the wheel at the turn limit (lock) will cause the most pressure..
Sam
Old Aug 26, 2009 | 08:05 PM
EXv10's Avatar
EXv10
If you wrap the points in question with something you can narrow it down that way.
Old Aug 26, 2009 | 08:47 PM
Monster-4's Avatar
Monster-4
Have you had any work down at anytime with the PS pump, steering box, brake booster, anything?
Old Aug 27, 2009 | 08:20 AM
Jim McCarty
I’m not ready to find a new mechanic yet. Ford said the problem was that I needed a new steering box that costs over a grand. I think just because there is a leak does not justify changing out the entire steering box. This guy says he won’t charge anything if he can’t find the problem.
There is a coating of oil all over everything around the power steering system, but not a drop anywhere. It is all or nothing.
I am going over there this morning and try holding it at full left or full right. My logic says it has to be a valve sticking somewhere in the pump since it is all or nothing. I think I’ll have them flush the system, refill, tie rags around suspected areas with plastic ties and drive it a little while to see what happens next.
Old Aug 27, 2009 | 10:15 AM
EXv10's Avatar
EXv10
There you go.
