Drilling a hole through a cement wall...
Old Aug 25, 2009 | 07:04 PM
preppypyro's Avatar
preppypyro
Hey there guys n gals.
Im looking to install a outside water tap on the walkout part of our house. We have a insulated concrete form basement (ICF) and I believe I will have to drill a 1 inch hole through the foam and cement filled block. (blocks have 8 inches of cement in the middle with 2 inches of foam on each side, so the total width i would need to drill through is about 12 inchs)
Im unsure of how to do this, can anyone steer me in the proper direction?
Old Aug 25, 2009 | 07:19 PM
*2fords*'s Avatar
*2fords*
For a hole that big it would be best to use a hammer drill. I believe you can rent them at any rental place for around 35.00 a day plus the concrete bit.
I'm pretty sure they don't make a concrete bit that big for a regular 1/2 drill.
Old Aug 25, 2009 | 07:50 PM
preppypyro's Avatar
preppypyro
I do have a hammer drill, but I believe it is a 1/2 inch one too.
I was hoping to buy what I need, but renting might be an idea.
Old Aug 25, 2009 | 08:12 PM
rollerstud98's Avatar
rollerstud98
Do you have a home hardward near you? If so they rent large bosch hammer drills, you'll want some substantial for doing what you are doing, not sure if your drill is just one of the small type that you can put it to hammer or not but if it is you'll be at it for a long time with that sucker!
Old Aug 25, 2009 | 08:29 PM
AzBlueWolf's Avatar
AzBlueWolf
I vote for renting a hammer drill...shouldnt take more than 10 minutes to drill it
you could use your own hammer drill with a 1 inch masonry bit and an extension...
I would drill a 1/4 inch pilot hole...your concrete is still fairly green and you might get lucky.
Old Aug 25, 2009 | 08:37 PM
websthes's Avatar
websthes
Rent a hammer drill. Shouldn't take you that long. PUll the bit out from time to time as you're drilling to clear out the cement dust.
If you're drilling from the outside, point the bit up a little so your hole slopes towards the outside. That way when you close the valve in fall, there won't be any water left in there.
It's also a good idea to pick up the outside faucet when you're renting the tool, so you can make sure you have the right sized bit, and check that it fits in the hole before you bring back the tool. I have Pex plumbing in my house, and the pex faucet was quite large.
Old Aug 25, 2009 | 08:40 PM
AzBlueWolf's Avatar
AzBlueWolf
make sure you put a shut off valve inside too...for winterization!
you might have to remove some insulation temporarily if you cant get a 12" long bit...
Old Aug 25, 2009 | 09:00 PM
shorebird's Avatar
shorebird
Actually what you want is called a Rotary Hammer. It is a different tool from a hammer drill.
http://www.lowes.com/lowes/lkn?actio...uidedrill.html
Rental is the best for occasional use.
Old Aug 25, 2009 | 09:49 PM
BLK94F150's Avatar
BLK94F150
Rotary hammer is the only way to go for what you want to do. A 1/2 inch hammer drill is not. Shouldn't take long at all and you're much better off renting as the hammer and the bits are usually very expensive. When I worked for the road dept. I could drill 30 holes like that in a pretty short amount of time. Make sure you use a frost proof silcock. They even make ones now that won't break if you leave the hose hooked up and it freezes.
Mike
Old Aug 25, 2009 | 09:53 PM
jimlj's Avatar
jimlj
Drill a small pilot hole throuth the wall first. Next drill most of the way from one side with the 1" bit, then go to the other side and drill the rest of the way through. If you don't you are likely to blow a big chunk of concrete and foam off as the big bit breaks through.
Old Aug 25, 2009 | 11:05 PM
preppypyro's Avatar
preppypyro
Thanks for all the advice fellas!
My woman bought the tap already, and we have a shut off for the inside. Also great tip about sloping the tap, which I was gonna do anyways (I do alot of sloping when I dig trenches and whatnot, and I know how important that is)
Looks like my cheap *** has gotta go rent something!
Old Aug 26, 2009 | 01:13 AM
AzBlueWolf's Avatar
AzBlueWolf
well...you could go spend $1000 on a rotary drill and bits and only use it once
Old Aug 26, 2009 | 05:46 AM
fonefiddy's Avatar
fonefiddy
Pilot holes are not necessary, or recommended with concrete bits. The tip of the bit does most of the chipping. Drill a pilot hole and you lose this effect with the larger bit.
Old Aug 26, 2009 | 07:07 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You'll want to use a coring bit.....more or less the masonry equivalent of a hole saw.
Old Aug 26, 2009 | 08:15 AM
AzBlueWolf's Avatar
AzBlueWolf
coring bit for a 1" diameter hole?
