No Fuel Delivery
Old Sep 8, 2002 | 08:33 PM
Indy63F100's Avatar
Indy63F100
No Fuel Delivery
Greetings All, I've posted this qwander in the 61-66 board but thought I'd see if what I could find here. I cant seem to draw fuel from my in-cab tank to the carb. I've blown the lines out w/air so all seems clear. I've blown from the tank to the pump and get fuel to flow through. Test pump and get 3 1/2 psi. Put it all together and nothing. Is there something inside the tank I need to check?? Anyone run into this before?? Thanks
Indy
Old Sep 8, 2002 | 10:11 PM
Mike W's Avatar
Mike W
No Fuel Delivery
Check for air getting into the line from the tank. Did you check the pump pressure while on the engine? Is the vent on the gas cap ok? Let us know.
Old Sep 9, 2002 | 03:00 PM
ledgeclimber's Avatar
ledgeclimber
No Fuel Delivery
