ATOMIC BACKFIRE
Old Aug 13, 2002 | 10:58 PM
hairball12's Avatar
hairball12
ATOMIC BACKFIRE
I went from the frying pan to the fire with this one.
After replacing a carb that was causing problems, hard starting,
stalling, leaking, then a fire. I wound up with a new problem.
When I let off the gas at high speed I get one single large backfire.
The other prombles are gone and the truck runs good except for the backfire.
There is a condenser mounted to the coil but the wire got burned in the fire and I am not sure what the wire was connected to. Could this be the problem? Do you know where that wire goes? Thanks
Old Aug 15, 2002 | 01:31 PM
beartracks's Avatar
beartracks
ATOMIC BACKFIRE
Sounds like excess fuel burning off. You might be real rich or you could be pulling fuel out of the squirter nozzles. High float level?
Old Sep 17, 2002 | 01:48 AM
dpoelstra's Avatar
dpoelstra
ATOMIC BACKFIRE
the condensor attached to the coil is for radio interference. I believe it goes to the negative side of the coil, but you don't need it and it has nothing to do with your problem.
Old Sep 18, 2002 | 12:12 AM
dpoelstra's Avatar
dpoelstra
ATOMIC BACKFIRE
ColtonMullis
Dec 31, 2013 07:56 PM
MikeFlorida
Feb 18, 2007 05:23 AM
bobonut
Jan 11, 2005 12:33 AM
hairball12
Aug 15, 2002 07:02 PM
Jesse Wardlow
Jun 28, 1999 11:53 AM
