Lean Condition Causing Backfire???
86 F350 CC DRW, 460/C6, new Edelbrock 750, new Edelbrock roller timing chain set at straight up. New plugs and wires before the timing chain installation.
Immediately after installing the timing chain, I developed a backfire through the carb problem. Replaced all of the ignition components (module, coil, distributor, cap-n-rotor), and found that the only thing that made it better was to advance the timing. Retarding the timing made it REALLY bad.
Now, I have the timing advance to about 30 degrees using the hot start method, and the truck runs fantastic. But...
Today I had to take 15 mile freeway run. In the first five minutes this afternoon, it backfired once and ran fine the rest of the way. However, tonight about 11pm on the way home it was backfiring through the carb every 4 or 5 minutes.
It does it more in cool air...
It NEVER has done it under hard acceleration, or deceleration. Only high steady speeds on the freeway, say above 2500 rpm. Other than this the truck runs fantastic.
A guy at the local speed shop told me that if I installed the roller timing straight up, I could create a lean condition.
Is this true, and will this cause my backfire?
What else could be causing it. Do I need to reinstall the timing set to 4 degrees retard (don't wanna)? Plugs and wires are fairly new.
If I need to enrichen (is that a word?) my carb, will the adjusting screws do the job, or will I need to change jets?
I tow a heavy trailer with this truck, so I need it right.
Please help me out here. Thanks.
Could I be too far advanced? I've heard of guys running this far advanced with no problems, as long as it is not pinging. I can't get the thing to ping, but I haven't towed my trailer with it this far advanced.
I will try to run it richer and see what that does.
Any other suggestions?
Thanks...
the marks should be close together top mark at 6 oclock and the bottom mark at 12 oclock
was it a 3or more key sprocket?
had a friend install new timing chain cause his was bad.
truck was towed home! the book said to replace everything as found... couldnt get it running when done, had to put dist way out and it ran poorly.
i helped him take it apart and found marks were off.
when i moved the cam he ran and got the book saying i was doing it wrong. put it back my way... and now running fine.
might not be same as your case but ''stuff'' happens
jason
I just was not expecting to run so lean from advancing the cam timing, but I just learned too that the Edelbrock 1411 750 cfm comes out of the box with the biggest metering rods they make, making it run as lean as possible, probably for emmisions and economy. Plainly put, this carb simply can't get any leaner.
I also was not expecting it to pop through the carb from running lean.
I've learned alot in the last week.
