Help
Old Aug 24, 2009 | 07:16 PM
30dodge's Avatar
30dodge
Help
86 302 motor, fuel injected, I used throttle body cleaner the other day because ever since owning the truck I would have to double foot it when coming to a light so it would not stall and I figured it might help. Can said to squirt in while engine not running, I thought I was smarter and squirted in ( ALOT ) while it was running and I was opening the throttle. Now it will often ( but not always ) surge while idling, up and down, up and down. What can I do, do I have a bad throttle position sensor and did I only make it worse?? Thats my guess but I am just pulling that out of my hat. Thanks for any help
Old Aug 24, 2009 | 10:19 PM
carnut122's Avatar
carnut122
Pull and clean the Idle Air Control Valve??? That's my best guess. Also, some of the electronics and cleaner don't play nicely together.
Old Aug 25, 2009 | 05:52 AM
30dodge's Avatar
30dodge
I will look into that, thanks
