what does this mean..
Old Aug 24, 2009 | 07:13 PM
zman1202's Avatar
zman1202
i got my truck running finally off a 5 gallon tank of diesel hooked up to the feed pump. but the crankcase breather was putting out some smoke or steam or something im not sure but it was quite a bit. does someone know if that is normal for a diesel.
Old Aug 24, 2009 | 07:23 PM
joe f350's Avatar
joe f350
good it worked the smoke out of ur crank case is called blow u have a turbo i dont know much about the blow buy wilth a turbo on ur truck back ot no start prolbem this means u might have a bad sending units air in the lines some where behind the feed pump but know u know where to look
Old Aug 24, 2009 | 07:24 PM
joe f350's Avatar
joe f350
or u could have a bad cdr vaule iam just glad u hot ur truck runing i know ot suck to have a truck u cant drive lol
Old Aug 24, 2009 | 10:03 PM
Dave Sponaugle's Avatar
Dave Sponaugle
With a 22.5 to 1 compression ratio a decent amount of blow by is normal.
Old Aug 24, 2009 | 10:11 PM
dyoungen's Avatar
dyoungen
I removed the CDR a few months ago, cleaned it and put it back on. When I was finished I ran the truck and when I looked down the intake there semed to be a lot of "smoke" going down the intake. Is that normal, like a pvc on a gasser?
Old Aug 25, 2009 | 08:29 AM
zman1202's Avatar
zman1202
Ok Thanks alot joe probably still would be looking past those lines thanks again
Old Aug 25, 2009 | 02:17 PM
joe f350's Avatar
joe f350
ur welcome i went threw that same thing let me quess ur patneys touhg tu bought a lemon and wonted let ot go at less thats what mine did
Old Aug 25, 2009 | 02:27 PM
whiskeyrichard's Avatar
whiskeyrichard
yup, that is 100% normal.
Russ
Old Aug 25, 2009 | 08:17 PM
dyoungen's Avatar
dyoungen
Thanks Russ, that gives me a little more piece of mind
Old Aug 25, 2009 | 11:21 PM
joe f350's Avatar
joe f350
i just replace all my ruber lines it was like 20 buck but never had a prolbem with it since
