check engine light and stalling
Old Aug 24, 2009 | 07:29 AM
ohardy's Avatar
ohardy
Hey guys, My father has an '03 F250 7.3L power stroke. Lately he has been having trouble with it stalling out while driving down the road mainly when you let off the gas I have already changed the cam sensor and it still does it. Recently I drove it to virginia about 3 hour trip and never had a problem with it stalling but did have the check engine light come on I pulled the codes and it read "P1280 injection control pressure out of range-low and P1211 control pressure above/Below desired" What could be causing this? the only upgrades It has is the pcm programed with an edge programmer at the highest setting and a 4" exhaust
Old Aug 24, 2009 | 08:08 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Take the Edge off and go back to stock, see if that stops the stalling. Those codes are normal with a chip/tuner.
