sticking throttle
Old Sep 23, 2002 | 09:40 AM
johnsonacres's Avatar
johnsonacres
sticking throttle
Does anybody know what would make a 81 302 2v carb throttle stick at pretty high rpm. It does it on both cold and warm engine (choke open) and even if i take the gas pedal linkage cable off. It will idle if you kick it down hard, or manually do it on the carb. The carb feels like its in a bind and very stiff, but when i turn motor off, the carb throttle is smooth and not in a bind. Is the carb just messed up? I'm going to replace it with a 4v intake and carb but hate to not fix this problem as it might be there with the new set-up. You know bad vac lines, air pump, egr valve, etc. Any help would be appreciated. The plugs are black and sooty. I know that means its rich.
Thanks,
Keith
Old Sep 23, 2002 | 01:33 PM
Vampiro's Avatar
Vampiro
sticking throttle
maybe firstly try cleaning the carb well with gunk carb cleaner. there may be a bild up of gum and stuff with needs to be cleaned out. or maybe a cable is broken or a vacuum line somewhere
Old Sep 24, 2002 | 06:06 PM
paveslave's Avatar
paveslave
sticking throttle
I had this problem on my 84 and believe it or not, there were no return springs on the throttle which made it act like it was sticking. Atozone had a universal set for $3 and it worked like a champ. I didn't mean to insult your inteligence if this wasn't it, but it worked for me.
-Ry
-If it aint broke, fix it till it is...
1985 F-150 302 4X4
Dana 44 TTB / 9 inch
4.56:1 Front/True-Trac
4.56:1 Rear/Detroit Locker
C-6 Tranny, NP208 Transfer
6 inch Skyjacker Class II lift
35 X 12.50 BFGoods AT's
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6674&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=8776&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6675&.jpg https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=6703&.jpg
Old Sep 26, 2002 | 07:35 PM
HD61cuin's Avatar
HD61cuin
sticking throttle
