Torque wrench range
Old Aug 24, 2009 | 05:03 AM
ChunderDownUnder's Avatar
ChunderDownUnder
Torque wrench range
Howdy bro's and bro ettes.
Im looking at a inch/lb torque wrench. What torque range would be best for the PSD.
Old Aug 24, 2009 | 06:08 AM
F350-6's Avatar
F350-6
Up to 120 in-lb at a bare minimum. A lot will depend on how low your ft-lb torque wrench will read. Mine starts at 10, but I don't trust it that low. I prefer to use the in-lb one below 15 ft-lbs (180 in-lbs)
Old Aug 24, 2009 | 07:47 AM
ChunderDownUnder
I have a Warren and Brown deflecting beam which starts at 10 ft/Lb. The Inch one I was looking at starts at 120inch. is that to starting point to high ?
Old Aug 24, 2009 | 08:10 AM
mueckster's Avatar
mueckster
Yes. That starting point is the same torque setting as the injector hold-down bolts. I prefer one that starts below my minimum torque setting. My click-type MAC 3/8'' drive starts at 5 ft-lbs/ 60 in-lbs. Basicly, both torque wrenches start at the same place.
Old Aug 24, 2009 | 08:14 AM
agg_bagg's Avatar
agg_bagg
ya if you figure that 12 In-lbs = 1 ft-lbs then you would want one that topped out at about 120 inch instead of starting there.
