...while I have it out.....
Old Aug 23, 2009 | 11:01 PM
whiskeyrichard's Avatar
whiskeyrichard
I am not a big fan of climbing all around on top of and underneath a vehicle to work on an engine. So I am going to pull the motor to do this work.
My motor has what looks to me like a leaky rear main, and also has some oil coming from the lower front. This oil has gone all over creation under the truck, so that needs to be cleaned as well.
My question is, what should I do to her while I have her out. Here is what I am planning on:
1) rear main seal
2) front crank seal if it needs it
3) oil pan gasket
4) steam clean the entire engine compartment and under carriage of the truck.
Is there anything else I should do while I have the motor out?
Also, do any of you know how much this thing weighs?
I have this http://www.harborfreight.com/cpi/cta...emnumber=67015 engine stand....will that hold this motor?
Thanks for the advice,
Russ
Old Aug 23, 2009 | 11:11 PM
joe f350's Avatar
joe f350
bore ans stroke it out
Old Aug 23, 2009 | 11:17 PM
whiskeyrichard
you must be getting ready to lend me some money with advice like that!
Russ
Old Aug 23, 2009 | 11:38 PM
joe f350's Avatar
joe f350
lol whill u got it out i whould check the turbo
Old Aug 24, 2009 | 05:08 AM
fonefiddy's Avatar
fonefiddy
Paint the oil pan
Old Aug 24, 2009 | 05:15 AM
Skip1970's Avatar
Skip1970
you could take pics of it when you get it done while its out.
Old Aug 24, 2009 | 05:38 AM
mistakenID's Avatar
mistakenID
I've seen weights on the engine from around 970 lbs dry to around 1100 wet. The engine stand should hold it easily.
Depending on your finances, you might think about new head gaskets and head studs while it's out. Head gaskets are a weak point.
Old Aug 24, 2009 | 05:42 AM
Skip1970's Avatar
Skip1970
arent them head studs liek 400 bucks too?? wow i say dont fix it if it aint broke when you talking that kinda cash!
Old Aug 24, 2009 | 09:20 AM
gnathv's Avatar
gnathv
Oil cooler: o-rings and gaskets
Old Aug 24, 2009 | 09:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Try this, 259 dollars at Summit Racing.
http://www.summitracing.com/search/y...s/?Ns=Rank|Asc
If the engine is out, I would do head gaskets, studs, oil cooler O rings and gaskets, front and rear main seals, oil pan gasket and probably check the heads out while they are off.
