rough at high RPM
rough at high RPM
My 97 truck has serious problems pulling any load at interstate speed. Like my 24 ft trailer with a 45 hp John Deere, I could barely get 65. Loads my old 6.9 with no turbo laughs at like its not there. Going up a hill, if you lock the overdrive out, it loses speed, with over drive out it will only pull about 60 mph, and it blows a lot of blue smoke. If the truck is in park and you mash it all the way to the floor, it revs to about 2500, hesitates there for about 3 seconds, then slowly builds to 3500, while blowing lots of blue smoke. I thought it was the fuel pump, I replaced that today, seemed to help a little, but not much and it still doesn't pull very good.
andy. you can clean your fpr screen and it should get you by. but yes its probly your injector orings given the blue smoke. heres a good write up on removal and install.
injector removal and install
