Tip on Changing The Fuel Filter on...
the bracket that holds the fuel filter comes off. it is a tight squeeze to get your fuel line disconnects in, but taking the bracket off makes changing the filter alot easier. i didnt find out it came off until after i wresteled mine into the mounted bracket though . That fuel line you're talking about was a pain for me, but i just got my disconnect partially in and rotated it and pushed etc until it came out. Just don't force anything and be patient
Also when trying to disconnect, them although many sources say you should hear a click, you probably won't. Assuming this is the first time you've done it, helpful info, if not well... disregard me...
Also if yours are like mine you may need something to pry the line off once you got it disconnected, but make sure you have it disconnected before you pry. You could damage the teeth.
