I just got in my AE from Clay and have done a little tinkering with it and am now (I think) ready to start checking things out.Biggest trouble is I have no clue as to what I should be checking or looking for LOL.I want to check my HPOP and also any other test that would be good as maintenance type things.Any and all help will be appreciated.
To check your HPOP, get into the live data monitoring screen, select ICP, duty cycle, and RPM to log. Get it ready to record. Go out to a road where you can roll into the throttle from 55mph or so and keep it floored until you run out of steam. Hit record and log the run.
Other items to log might be boost and throttle but logging too many things brings the sample rate down due to bandwidth. The sample rate is not stellar to begin with.
Usually there are Maintenance and Mod links on the left hand side of the RHN but it looks like something happened to them for a bit. Check them out, there are several links for the AE on there.
