how do I tell?
Old Aug 23, 2009 | 01:29 AM
adam83's Avatar
adam83
how do I tell?
If I am looking under the hood of an f250 and Im not sure if its a 78 or an older model with a 78 grill, how do I tell if it has the 78-79 power steering? What is the visual difference between the 78's power steering and the older power assist? How do I tell if it is power steering, and not power assist?
Old Aug 23, 2009 | 07:38 AM
fdude64's Avatar
fdude64
power assist has a hydraulic cylinder with the hoses going to it on the tie rod if im not mistaken
Old Aug 23, 2009 | 04:03 PM
adam83's Avatar
adam83
where is the power assist located?
Old Aug 23, 2009 | 04:36 PM
montana_highboy's Avatar
montana_highboy
The control valve is mounted between the pitman arm and steering knuckle and the hydraulic ram is mounted to your axle and tie rod.
Old Aug 23, 2009 | 04:51 PM
USArmyTaterness's Avatar
USArmyTaterness
or you could read the frame VIN number
