Sponsored by: Innova
Sound..
Old Aug 22, 2009 | 05:53 PM
FordNFishinLover's Avatar
FordNFishinLover
Sound..
Okay well i have had my stereo unit in my truck for awhile now, and i recently have gone back to redo the wiring better and got it all taped up good.
All is fine, but now the RIGHT side of my truck speakers are not as loud as they should. Its like they dont have nearly the bass or the sound as the left side. Yes you can hear them, but its not as it should. It makes me think its the wiring thats wrong because as you drive you can hear them cutting in and out from going to normal sound to the dampened sound.
Any ideas why this is happening? All my connections are good, and there are no wiring loose and touching....
Any help is very grateful!! Thanks
Old Aug 23, 2009 | 01:39 PM
FordNFishinLover
Problem FIXED~! Thank you all very much for your help!!!
As NAT had mentioned that i had a wire mixed up, turns out i did...
On my rear speaker i had my gray/black wire mixed with just the gray wire causing it to not work right. Easy fix and already done so im happy!!! THANKS AGAIN EVERYONE!!
