what gas octane needed
Old Oct 27, 2002 | 10:17 AM
Fordman7780's Avatar
Fordman7780
I building a 514 engine that has 11.8 compression and I wonder i premium gas 93 octane and octane booster will be enough because I want to be able to drive down the road and not have to run racing fuel
Old Oct 27, 2002 | 01:51 PM
heathdaily's Avatar
heathdaily
No
I would guesstimate you'll need about 105 octane fuel. Which is about 5-6 dollars a gallon and for off-road use only. You might could lower that by getting a big lumpy cam that will bleed off compression through vavle overlap. The problem is it'll run terrible at anything below 3-4 thousand rpm.
If you want to drive it, get the compression down to at least 10:1 or maybe 10.5:1 with a slightly lumpy cam. This assumes however that you're using aluminum cylinder heads. If not, drop it an additional .5 to 1, if you use an aluminum block you could raise it .5 to 1 but I doubt you'll like the price tag on that block.
By the way if you add a bottle of octane booster to gas it raises it 2 points right? Wrong. Read the bottle carefully, it's actually going to raise it .2 to 1, sucks don't it. You're 93 becomes 93.2 octane fuel.
Old Oct 29, 2002 | 02:22 AM
rebocardo's Avatar
rebocardo
ddlyarmbar
Arizona Chapter
Oct 18, 2006 12:05 PM
mck2000
Computer Chips & Tuners
Aug 14, 2006 03:55 PM
dansV10
Aug 24, 2005 02:26 PM
grizz5675
Modular V8 (4.6L, 5.4L)
Jan 8, 2004 01:41 AM
WXboy
Nov 11, 2003 11:33 PM
