I have a 04 Explorer sporttrack 4.0L V6 SOHC. While driving the other night the engine started to run rough so I got it home as quick as possible. I had trouble codes telling me the #5 cylinder wasn't firing and I tested and had almost no compression. I took off the valve cover and discovered that the exhaust roller rocker on #5 cylinder had come off as well as it's lash adjuster had come out. After looking at the roller rocker I discovered it had way too much play in the bearing so I replaced it and the lash adjuster.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o> After reassembly I had some ticking noises so I did and engine flush and then did an oil and filter change. I ran the vehicle for twenty minutes or so and with no more ticking I shut it off. After letting the vehicle cool off for a couple of hours I tried starting it again and then it felt like two cylinders weren’t firing. I would take off the valve cover again but it is pouring outside now.
<o></o> Any ideas what could be wrong?
I've not had much luck getting help on this "Explorer" forum in the past but hope you do.
My 93 Sport Trac is running rough and the diagnostic show #6 injector to be bad, so we change it out and no change at all .
I will keep an eye on this and maybe I can get help also on my 4.0 SOHC
Did you need to take off a few plug wires to get the valve cover off, or does your 2004 use CoP ignition? If you pulled plug wires, maybe a couple of them didn't get seated properly.
