Modular V10 (6.8l)
Sending Unit
Old Aug 21, 2009 | 09:55 PM
f2504x408's Avatar
f2504x408
Thumbs up Sending Unit
I have a 2008 f250 6.8 V-10 Can enyone tell me where the oil pressure sending unit is located,i'm going to put a steel braided hose in it's place and run it to a T Fitting and use my stock sender and a Auto Meter electric sender so i can get a better oil pressure reading. Thanks
Old Aug 22, 2009 | 09:02 AM
Monster-4's Avatar
Monster-4
I know on the 2V it's on the left side of the block near the engine mount. It's the only sensor in that area so it's easy to spot.
I'm not sure if the 3V is in the same spot.
Old Aug 22, 2009 | 09:46 AM
f2504x408's Avatar
f2504x408
Thanks Monster-4 that's where it is you have to get to it underneath behind power steering pump.
Old Aug 24, 2009 | 05:02 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
That's exactly what I did. I used a marine tilt/trim steel braided line with 5/16" flared ends.
mantta
2009 - 2014 F150
15
Dec 5, 2010 09:30 AM
f2504x408
Oil & Lubrication
Aug 21, 2009 07:32 PM
KDPate
Dec 12, 2006 01:56 AM
CougarMark67XR7
May 4, 2006 08:55 PM
