6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Tsb 09-16-8
Old Aug 21, 2009 | 02:59 PM
Hunter40's Avatar
Hunter40
Tsb 09-16-8
Anyone know what this TSB is?
Old Aug 22, 2009 | 10:54 AM
eric.long's Avatar
eric.long
I looked it up on ALLDATA and did not find that TSB listed the only one close was 09-6-8 and this is what that one said:
TSB 09-6-8
04/06/09
6.4L AIR INDUCTION SYSTEM RESTRICTION -
SNOW - BUILT ON OR BEFORE 3/16/2009
Old Aug 22, 2009 | 11:17 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
FORD: 2009 F-Super Duty
This article supersedes TSB 08-25-10 and 07-4-11 to update the Service Procedure.
ISSUE:
Some 2009 F-Super-Duty 250-550 vehicles and equipped with a 6.4L diesel engine may require a calibration update which will cover several different concerns.
ACTION:
Follow the Service Procedure steps to correct the condition.
NORMAL OPERATING CHARACTERISTICS - EXHAUST SYSTEM REGENERATION
This document provides additional information on the conditions of normal operation while the vehicle is in the exhaust filter regeneration process. These are normal conditions and do not require repair. For most driving conditions, normal exhaust filter regeneration will begin anywhere from 100-600 miles (161-966 km) from the completion of the last regeneration cycle. Each occurrence will last from 10-40 minutes.
The exhaust filter regeneration process will not initiate or may be terminated when:
The vehicle is stopped at idle for more than 5 minutes in gear.
The vehicle is operated in Power Take Off (PTO) mode.
Stationary Elevated Idle Control (SEIC) is engaged.
The gear selector is placed in Park or Neutral.
Vehicle characteristics change during the exhaust filter regeneration process:
Some white smoke in cold ambient temperatures is normal. The amount of white smoke during this time will be increased during exhaust filter regeneration.
The engine's peak power is modestly limited during regeneration.
Engine responsiveness may be slightly different than normal operation during regeneration.
Exhaust smell may be noticed during the exhaust filter regeneration process - especially on new vehicles.
The powertrain sound will be different during exhaust filter regeneration including air induction noise, combustion noise, flutter on deceleration or shut down.
SERVICE PROCEDURE
Reprogram the Powertrain Control Module (PCM) to the latest calibration before performing diagnostics and clear all diagnostic trouble codes (DTCs) after programming. For DTC's generated after reprogramming, follow normal diagnostic service procedures.
Reprogram the PCM to the latest calibration using Integrated Diagnostic System (IDS) release 61.19 and higher or 62.07 and higher. This new calibration is not included in the VCM 2009.7 DVD. Calibration files may also be obtained at www.motorcraft.com. When reprogramming the PCM on automatic transmission equipped vehicles the Transmission Control Module (TCM) will also automatically be reprogrammed to the latest level.
NOTE: REPROGRAMMING CONCERNS / ERRORS MAY BE CAUSED BY THE DATA LINK CONNECTOR (DLC) OR VEHICLE COMMUNICATION MODULE (VCM) BECOMING DISCONNECTED, LOW BATTERIES ON THE IDS OR THE IDS GOING INTO ANY TYPE OF SLEEP MODE, OR LOW VEHICLE BATTERY VOLTAGE. TO PREVENT VEHICLE BATTERY DISCHARGE DURING REPROGRAMMING A POWER SUPPLY CHARGER, ROTUNDA NUMBER 162-00043 OR EQUIVALENT, SHOULD BE USED. IF THERE WAS AN INTERRUPTION DURING REPROGRAMMING, MAKE SURE THE ORIGINAL IDS SESSION THAT WAS CREATED FOR THE VEHICLE IS NOT DELETED. IF THE ORIGINAL VEHICLE SESSION IS NOT USED OR DELETED BEFORE THE MODULES ARE COMPLETELY REPROGRAMMED, FURTHER REPROGRAMMING ERRORS CAN OCCUR. THE MODULE RECOVERY PROCEDURE IS NO LONGER AVAILABLE AND IT IS CRITICAL THAT MODULE SWAPPING IS NOT PERFORMED FROM VEHICLE TO VEHICLE. TO REGAIN COMMUNICATION WITH A MODULE THAT HAS BEEN ERASED DURING REPROGRAMMING, RESUME THE ORIGINAL SESSION ONCE THE IDS IS RE-BOOTED.
Calibration Update Includes:
Diagnostic and malfunction indicator lamp (MIL) operation improvements for DTCs P006B, P2563, P0108, P0234, P1260, U0073, P042E, P042F, P0404, P1335, P041C, P2457, and P2263 set during key on engine running (KOER) self test.
Improvements include revised pressure control valve (PCV) / volume control valve (VCV) learning tables for vehicles that exhibit DTCs P0087 and/or P2291 following replacement of the high pressure pump or major fuel system repairs. Reset the PCV / VCV learning tables and fuel injector parameters with IDS using the clear fuel injector parameters.
Enhancements for vehicles that exhibit white smoke during diesel particulate filter (DPF) regeneration at ambient temperatures below 55 °F (13 °C).
Improvements to reduce P0544, P2031, P242A, P242B, P2080, P2084 and P117B set on long decelerations after cold start.
Improved cold start drivability for vehicles operated in temperatures below 32 °F (0 °C).
Resolution for vehicles that exhibit a no crank condition, Failure Mode Effects Management (FMEM) continuous timer count down due to Exhaust Gas Temperature Sensor disconnect Powertrain Controls/Emissions Diagnosis (PC/ED) Pinpoint Test RC 4 key on engine off (KOEO) circuit diagnostics or vehicle battery disconnect.
IDS tool updates for DPF manual regeneration diagnostic testing referenced in PC/ED Pinpoint Test RB.
This calibration also includes the following instrument cluster (IC) message center display update: Clean Exhaust Filter.
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
091608A 2009 F-Super Duty Automatic Transmission: Reprogram The PCM/TCM/IC (Do Not Use With Any Other Labor Operations) 0.5 Hr.
091608B 2009 F-Super Duty Manual Transmission: Reprogram The PCM/IC (Do Not Use With Any Other Labor Operations) 0.4 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
recal 04
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2009 Ford Motor Company
Old Aug 23, 2009 | 07:32 AM
senix's Avatar
senix
Ed is a great resource!
Old Aug 23, 2009 | 09:17 AM
Hunter40's Avatar
Hunter40
Thanks Y2KFordparts!
Old Aug 23, 2009 | 04:29 PM
ruschejj's Avatar
ruschejj
Wow. Great info. I googled it and got a bunch of maintenance procedures for a F-18 Hornet.
Old Aug 24, 2009 | 01:14 PM
Parts Guy Wyatt
Former Vendor
welcome.
ed
jprix
Jan 18, 2014 08:04 AM
Hdslider
6.7L Power Stroke Diesel
17
Mar 2, 2012 03:48 PM
zecolleman
Oct 9, 2010 08:44 PM
DBLX
2004 - 2008 F150
Jun 3, 2009 06:12 PM
03Level_II
1983 - 2012 Ranger & B-Series
13
Jul 7, 2005 08:19 PM
