What Are You Doing To Your Truck?
#1111
#1112
#1113
Received 4,135 Likes
on
#1114
Need to get caught up on maintenance. Training for 2 weeks in VA, and there's apparently an auto-shop on base for the enlisted to use in their down time... so I packed the truck full of tools just in case.
The Bilsteins I put on a couple years ago are already useless. (Then again, they took a beating on the 5 freeway out in CA for a couple years... so i guess they've put in their time.) Need to find something more sophisticated this time around.
Haven't had any down time at home for even the little stuff - work's soaked up all my free time. Found a new job doing CAD and running the water jet table for a local fab shop in Fl. (Yes, they're as much fun as they look like on TV) Have access to the entire shop off-hours so, it's just a matter of time before I start in on truck parts.
#1115
In-dash radio/DVD/bluetooth (and) back up camera installed.
You can't really see it in the pictures but the JVC KW-AV70BT in-dash unit is too big for the opening and the removable faceplate/touchscreen sticks out about 3/4 inch. I discarded the bezel for the unit since it was too large for the stock opening in the dash (not the inside lips - the exterior opening in the dash).
The unit is cool because it's touch screen and has some neat features but I'm not sure I would recommend it because of the size issue.
Pictures attached.
Picture showing backup camera:
Picture of backup camera embedded in back bumper above hitch:
Picture of backup camera for perspective (to show how small the thing is):
Pictures of the bed floor restoration to follow in a later post.
Pictures attached.
#1117
Restoring the rusted bed floor.
Keep in mind it's floor plate so geting between the raised plate was a consideration.
Step 1 (no pre-work pictures): Used a wire brush attached to a drill to remove as much rust as possible. Decided the wire brush wasn't aggressive enough so I went to a flap wheel on my grinder. Burned through four wheels, but got the majority of what I needed to. Then went at the lower level stuff with a wire brush by hand. I could only tackle a bit at a time so this process took about two weeks. It's still not perfect but I was only trying to get rid of that which could be removed with the above.
Step 2: Applied Eastwood's "Rust Converter" product which claims to turn rust into a paintable surface. The product goes on white, seemed to turn a hazed blue in short order, and finally dried black after a day. I'm waiting for day three to apply the Duplicolor spray/roll on bed liner product. I'm using the Duplicolor product only as a top coat, due to its low cost, and thinking (based on other posts) that it likely will not hold up. I found when I did the wheel wells that it holds up better when you apply several very thin coats. Applying too much at a time resulted in a bubble that simply wipes off when you touch it at a later time.
A QUICK WORD ABOUT LINEX (LINE-X) which was my original preference. First off, I was told during my second trip to the North Hollywood Line-X dealer by Jennifer (who claimed that she previously worked for LineX corporate) that Line-X is only warranted on new vehicles that have a clean original coat of paint. I was also originally told by Line-X North Hollywood when I stopped by the first time that he would do the floor of my truck for $275 if I prepped the bed floor and $350 if he did the prep (my bed floor is 50" by 108"). He specifically told me that he would sand the floor, use the POR-15 product to first treat the rust and then coat the floor with their product. After prepping the floor, I went back to see if the prep was sufficient for the $275 price, or if they wanted me to do more work. At that time, they advised me that they could only do the work for $375, and that they would not do the work as previously quoted. I did not previously get an estimate, but took the guy at his word. For those that know me, the $25 incremental cost is an insignificant cost in the scheme of what I have already spent. But this business did not honor their original quote and I have chosen not to do business with him. I further caution any of you thinking about doing business with Line-X North Hollywood to rethink your choice or proceed with caution.
Pictures attached (don't know why but you'll have to turn your head sideways for pictures 1, 2 & 4):
I need to seal the Rust Converter with something (paint or otherwise) so the Duplicolor Bed Liner is a crapshoot. I haven't heard good things but I'm going to give it a try.
If the Duplicolor product fails, I will likely purchase a thin sheet (20G) of new floorplate in the coming months and weld that over the Duplicolor bed liner product.
I'll post pictures after I apply the Bed Liner and let you know how it goes.
#1118
#1119
Don't know - Ebay link is as follows: New Waterproof E305 Car Back Up Rear View Day/Night Camera NTSC 628X582 Pixel | eBay
Selling point for me was that they said it's waterproof. The next time I launch the boat, I'll be testing the waterproof claim.
#1120
Pop
#1121
I'm hopeful that the Eastwood Rust Converter product does what it advertises and will stop the additional rust from spreading upwards. Of course, it may continue rusting in a downward direction (it actually doesn't seem too bad looking from the street upwards), but I can only do so much to rescue this floor.
Hence the comment that it may ultimately get new floor plate.
#1122
#1123
#1125
Oh and djed - that back up camera setup looks cool. Thinking about trying for something like that in the crewcab!
