What Are You Doing To Your Truck?
#918
#921
#922
Just 'cause I don't keep up with the Six-Oh's, but Bro Bob does, what ARE the HPO known weaknesses? He's got that crew-cab '06 (I think) with one.
I gave him a coolant filter, and he's got that installed.
What else should he be addressing until an injector gives up, or the EGR cooler or oil cooler clogs?
Pop
Pop
#923
There's an updated 1 piece fitting for where the branch tubes connect to the HPOP. There have been a lot of failures of the original snap-to-connect (STC) fitting. there's also an updated standpipe.
Here's some pics: This is the original STC fitting shown:
This pic is of an '03, which uses a different pump and oil rails, but the flow path is the same and it shows the standpipe:
#925
Congrats on the new parts, Steve. Is that the newer Garrett Powermax turbo?
#926
#927
#929
Thanks for noticing!
The crank is longer again. I think I mentioned that this has been coming and going for a year or so. Doesn't matter if the engine is hot or cold. I watch the ICP while cranking, and it takes longer than it should for the pressure to build, and then once it comes up to 500 the engine bursts to life. So I think air is entering the system when the engine is off, and the pump has to reprime.
Could be the IPR, but I think it will be the STC fitting. If you have an '05 or an early '06 with that fitting it is probably just a matter of time before it fails.
Any guesses on what the dealer will charge me?
#930
