What Are You Doing To Your Truck?
#766
#767
I did it for injector longevity. I think they sound a little better when in high idle mode of 1200. Plus, I wanted a fuel pressure gauge so that I could monitor the safe pressure minimum, and you have to open the regulator cap to install that. I'm not looking for improved performance, but it made sense to do it all at one time.
#768
#770
#771
#772
#774
Cleaning out the bed of my truck. The trees on my street suck. That and I had left some oil in the bed too. Just spilled oil from old jobs. At least it won't rust but it makes a mess. I cleaned out, swept, rinsed, reswept and rerinsed with soap and water a bunch of times. Glad they had dish soap at the 99 cent store.
#775
Broken tap
Didn't leave anything to get ahold of. How the heck do I get that out of there?
#776
Uh oh.
There are tap extracting tools, but I've never had much luck with one. If you can get one it's worth a try. Short of that or an EDM, the only thing I know to do is to shatter the broken piece with a chisel or punch...which in this case would almost certainly drive the broken off pieces right where you don't want them to go.
#778
WaaaaWaaaa. Ok, I'm better now, that was great advice!
I used my infinite wisdom (don't tell my wife I have infinite wisdom; you'll make her laugh) and drilled yet another hole and tapped gently. Forced grease in the 2nd zerk'd hole and held a rag over the broken tap until grease came out the seams of the ball joint. Cleaned and covered the formerly oozing grease from the broken tap, covered in a small hill of silicon (upside down hill that is). Guess i best order a lower ball joint now...
#780
