tuning help
I have also been playing with the timing and reading as much on vac advance as I can find on the web trying to teach myself the basics. when my vac advance is on ported vac it doesn't move every time the throttle is cracked or revved and I have plenty of vac on that port its very in consistent but when its set to manifold vac it works properly other than it appears to be advancing the spark at high rpm and I thought it was supposed to go the other way retard the timing at high rpm or WOT. I tried setting it to the factory timing specs 8 degrees BTDC with the vac advance hooked to ported vac, I hooked our empty16' lowboy utility trailer (1200-1500lbs)to the truck and and took her for a road test and again it failed miserably pulling small grades at 30-35 mph and sometimes having to shift into 3rd gear. I am thinking maybe a bad vac advance can or maybe the 3.54 gears are just to high for the mountains around here. the thing gets me about this truck is it runs and pulls great by itself but if you put the slightest load on it the truck falls on its face and if she even smells a hill she quits pulling.
I mainly bought the truck to tow with but now I want to restore the truck so I'm gonna keep it and I like tinkering around with the truck but this pulling problem is getting the best of me. maybe I'm expecting too much out of the engine and gear combo but I have a buddy with an 88 F150 with a 300 six although it is EFI it has 3.08 gears (special ordered for fuel economy)and it will out pull this truck when towing similar loads.
sorry for the long winded post just needed to vent a little I suppose
by the way everything you just said goes against what I was reading on the web. don't get me wrong please I'm not saying what you said was wrong just what I have been reading was the exact opposite and I've been told both ways by mechanics.
I am a diesel mechanic by trade but I am a complete idiot when it comes to gas engines and all of my diesel experience (9 years) is on electronic/turbo charged diesels which I understand and know very well but I have never worked on gas engines very much other than regular maintenance and external parts like starters,alts, and water pumps etc.. I am actually enjoying learning gas basics and on these older simpler engines it fun to me to learn something new. I got some info off of a mustang forum I will post it after this. but the info is opposite of what you just said please read it and tell me if it makes sense. the author was originally a GM man converted to Blue Oval so he references the timing on a small block chebby some but I am asumming that the basic principles are the same.
thanks again
ARTICLE FROM THE MUSTANG FORUM.
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
My 1986 with 4.9L engine has been converted to Duraspark with non-feed back carburetor and has no EGR. The vacuum advance is connected to ported source (as original). The truck runs well with 14 degrees initial timing without pinging, but the coolant temperature creeps up at idle with or without the A/C being on. I will try using full manifold vacuum this weekend.
at 2 grand the centrifugal advance has the spark at 34-36 and at idle the vac takes over. the truck starts great and idles smooth. I haven't got to road test her yet but by what we have been discussing and the article that I read it should be pretty close. I hope to drive her tomorrow and let y'all know something
If this doesn't fix it I'm gonna check my fuel pressure I probably should have checked it before now. I rebuilt the carb a while back too but it didn't help. I hope this timing gets its straight
First off, your compression numbers are pretty strong.
I was chasing my tail a while back, thinking that I had an ignition timing issue.
I didn't have any means to measure my mechanical advance, so I
had to take my distributor to a speed shop to have it spun and measured.
Turned out that it is advancing my timing 14* at 4000 rpm... very conservative.
With a vacuum gauge and my timing light, I measured my vacuum advance
to be "all in", retarding my timing by 12* at 6" of negative pressure... yes,
retarding the timing with the throttle wide open. (My measurements
were verified by the guy at the speed shop.) It seemed backwards to me at
the time, too. My Ford shop manual explained that to be the correct function
of the vacuum advance though.
And smoke20, 21" at idle is real strong. What elevation is your area?
Murph.
