Non EBPV Pedistal ?
Old Aug 19, 2009 | 04:47 PM
Rich in CO's Avatar
Rich in CO
Non EBPV Pedistal ?
I'm installing a non ebpv pedistal and was wondering what do I do about the butter fly? Do I wire it open, just leave it?
Also is there some thing else I need to do that I missed from reading the past threads or is it just intsall the pedistal & go.
Thanks
Rich
Old Aug 19, 2009 | 06:01 PM
mueckster's Avatar
mueckster
You can grind off the rivets on the EBPV shaft and drive them out to remove the butterfly valve. Remove the shaft and bushings and install, IIRC, 20mm expansion (freeze)plugs in their place. Some have mentioned that they welded the holes shut.
Old Aug 19, 2009 | 06:06 PM
Rich in CO's Avatar
Rich in CO
Thanks Muck, but I don't have a welder or grinder, so I'm assuming I can just wire the valve open
Old Aug 19, 2009 | 06:41 PM
F350-6's Avatar
F350-6
Yes wiring it open is an option. Just remember if you wire it a little loose, it will partially close with the throttle resulting in reduced power and lower MPG's. Wiring will work, just make sure that sucker is tight so it doesn't flap around.
Old Aug 19, 2009 | 10:03 PM
Rich in CO's Avatar
Rich in CO
Thanks for the info guy's after looking at it for a bit I drilled the rivets out & cramed a freeze plug in, and i'm good to go.
Old Aug 19, 2009 | 10:11 PM
mueckster's Avatar
mueckster
Good deal. A couple of less things to worry about now.
