Hedman headers and full exhaust
Old Aug 18, 2009 | 11:06 PM
95f250's Avatar
95f250
Hey I have my mind set on a set of elite series hedmans they are very heavy duty it seems does anyone know if they are good and when I run the rest of my pipe is 2.5 or 3 inch better
Old Aug 19, 2009 | 09:11 PM
95f250's Avatar
95f250
Hey my headers came in and their great what do u guys think I should do for pipe routing and size? Are they good headers
Old Aug 20, 2009 | 01:09 PM
Beechkid's Avatar
Beechkid
Recommendation: based on my past experience (1970's) with Hedman products, I would highly suggest re-welding the head pipes at the head connecting flange. Perhaps they have changed their assembly techniques, but they use to be known for leaks at these locations. I use to run a bead weld on the side away from the head (the side you can see after install) around 100% of the pipe, then check the flange mating surface for straightness. this was the only way i could keep em sealed.
With regards to the pipe... You can run 3" all the way or step down from the collector to 2" or 2 1/2" (sizing specifically for your selected muffler- I would go with the largest diameter that I can to match the collector), using tailpipes in any combo of 2", 2 1/2" (duel) or single/duel 3", etc and you will be fine.
Old Aug 20, 2009 | 10:11 PM
Mustang6147's Avatar
Mustang6147
Run 3 inch all the way. Thos 2 or 2 1/2 belong on a ranger or a tempo... I hate seeing thos little pipes on a V8... They rob so much power.
