gauge install instructions
Old Aug 18, 2009 | 10:02 PM
rat49f6's Avatar
rat49f6
i know they are cheap gauges but thats what i could afford right now
im looking for picture instructions for installing these gauges
60 psi boost
http://www.glowshiftdirect.com/tinte...ost-gauge.aspx
2400* F pryometer
http://www.glowshiftdirect.com/tinte...ter-gauge.aspx
100 psi fuel pressure
http://www.glowshiftdirect.com/Tinte...ure-Gauge.aspx
thanks in advance
Old Aug 18, 2009 | 10:04 PM
HKusp's Avatar
HKusp
http://www.dieselmanor.com/diy/PSD3-...73gauge-p1.htm
Here are Diesel Manors very good version for Isspro's. They should work for you. Good luck.
Old Aug 18, 2009 | 10:08 PM
strokersace's Avatar
strokersace
I used the Diesel Manor instructions as well when putting in the Dipricols I used to have. Very straight forward and will work for different brands of gauges.
Old Aug 19, 2009 | 06:27 AM
rat49f6's Avatar
rat49f6
2 questions:
how do I get to the location shown in diesel manor's pyro instructions?
Any instructions for the fuel pressure gauge?
Old Aug 19, 2009 | 08:24 AM
03_PSD's Avatar
03_PSD
That fuel pressure gauge can be connected to one of the test ports on your fuel bowl. You'll have to have a special fitting to go from the fuel bowl to your sending unit. I bet your sending unit is 1/8 npt? Guzzle sells the adapert if it is or you might be able to find it at a parts store possibly.
Edit: 60 lb boost gauge is high, can you get one with 30 llbs?
Old Aug 19, 2009 | 09:49 AM
rat49f6's Avatar
rat49f6
The 30 psi one they had was vaccum / boost and I don't like the way it looked
And I will probably set them up so normal operating range is straight up and down so u can tell if something is wrong aquicker glance
Old Aug 19, 2009 | 09:52 AM
03_PSD's Avatar
03_PSD
They show to have a 35 lb. gauge with out the vaccum.
Old Aug 19, 2009 | 10:55 AM
strokersace
Originally Posted by rat49f6
2 questions:
On driver's side exhaust manifold. At the back of it right in front of where the up-pipe attaches to it.
Lay under the truck and look up at the manifold. You'll see it.
Old Aug 19, 2009 | 11:02 AM
rat49f6's Avatar
rat49f6
Yeah I guess it either was out of stock or not part of the package ...
Is the 60 psi bad for some reason?
Old Aug 19, 2009 | 11:05 AM
03_PSD's Avatar
03_PSD
Its not bad, but you'll never see above 30 lbs, unless you get alot of other stuff done to your truck.
Old Aug 19, 2009 | 11:07 AM
danskool's Avatar
danskool
Go Bills !
Location.Above the oil filter is were you will find the exhaust manifold that is shown in the picture. I know the picture gets you all twisted looking at it but if you crawl under and look for oil filter then look up you will see the manifold.
http://www.dieselmanor.com/diy/PSD3-gauge/image27-2.htm
Old Aug 19, 2009 | 11:34 AM
rat49f6's Avatar
rat49f6
Iirc it is also accessable through the wheel well?
Old Aug 19, 2009 | 11:51 AM
danskool's Avatar
danskool
Go Bills !
I think from under you have the best acccess. It is wide open. Can drill and tap it easily..
