2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
A/C and Advance Trac Problems
Old 09-01-2009, 10:00 AM
cjgeorge32's Avatar
cjgeorge32
cjgeorge32 is offline
I am having a couple of problems with my 2007 Expedition (25k miles).
The A/C (front and back) goes completely cuts out while I am driving for and stays out for about an hour. This has happened three times. Something strange happens right before the A/C cuts out… when you press the fan up button the fan blows lower and when you push the fan lower button you fan blows higher. Other than that problem the A/C works great.
Another problem I am having is that when I am driving the car with the Advance Trac (car with the lines under it) appears in the odometer area. It goes away rather quickly.
I am not sure if the problems are related or it could be an electrical issue….please help.
Old 09-01-2009, 10:16 AM
berry1234's Avatar
berry1234
berry1234 is offline
There are some TSB's referring to these problems, here you go.
TSB 08-9-1
05/12/08
EATC BLOWER INTERMITTENTLY INOPERATIVE -
STUCK ON HIGH/OFF
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
ISSUE
Some 2007-2008 Expedition and Navigator vehicles equipped with Electronic Automatic Temperature Control (EATC) may exhibit a condition where the blower motor is inoperative no matter what speed or temp setting or the blower motor is stuck on high speed or off. Cycling the ignition may resume operation. The concern may also occur when using the electrical power point.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Open the glove box and remove Connector C297 from the Heater Blower Controller Module (HBCM).
2. Remove the right front door scuff plate.
3. Remove the right side kick panel to gain access to Ground G200.
4. Cut black/white wire about 8" (20.3 cm) from C297. Strip the end 1/4" (6.3 mm).
5. Obtain pigtail kit and using the approved splicing methods found in the Wiring Diagram (WD), Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 13" (33 cm) pigtail and the black/white wire from C297.
6. Disconnect the existing 14401 single ground eyelet from G200 and cut existing eyelet from the ground wire.
7. Strip 1/4" (6.3 mm) insulation from the 14401 ground wire.
8. Using the approved splicing methods found in the WD, Cell 5, crimp the butt connector and seal (with shrink tubing) the splice between the 3" (7.6 cm) pigtail and the 14401 wire.
9. Attach the new interlocked ground eyelet to G200. Torque to 11 +/- 1.6 lb-ft (15 +/- 2.3 N.m )
10. Install the right side kick panel and scuff plate.
11. Replace the HBCM.
12. Attach C297 to the HBCM.
13. Close the glove box door.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
080901A 2007-2008 0.5 Hr.
Expedition/Navigator:
Replace The HBCM,
Includes Time To Isolate
Ground (Do Not Use With
19700D8, 14200A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
19E624 42
TSB data for: 2007 FORD EXPEDITION
Bulletin Number: TSB-08-14-2
Sequence Number: 10026363
Date: 20081022
Component Name: 024000 SUSPENSION:AUTOMATIC STABILITY CONTROL (ASC)
Make: FORD
Model: EXPEDITION
Year: 2007
Summary:
FORD/LINCOLN: STABILITY/TRACTION CONTROL INDICATOR; SLIDING CAR ICON: ON OR FLASHING; DTC C1996 OR SENSITIVE ESC/RSC ACTIVATION NO CODES. AFFECT SOME 2007-2008 EXPEDITIONS AND NAVIGATORS. *PE
Old 09-01-2009, 06:17 PM
cjgeorge32's Avatar
cjgeorge32
Thanks Barry...we can always count on you....
I am now dealing with a new problem....the parking brake light is on and dinging even though the parking brake is not engaged..I am more and more thinking that it is an electrical problem. Too many things happening at the same time.
Old 09-02-2009, 10:20 AM
berry1234's Avatar
berry1234
No problem. I would take it in. I didn't see any TSB's for the brake.
Old 09-02-2009, 11:14 AM
slc10844's Avatar
slc10844
slc10844 is offline
Release the parking brake and pull up on the pedal at the same time. Maybe the pedal isn't releasing all the way.
wpnaes
08-11-2017 01:20 PM
06FUN
10-29-2016 07:53 AM
0gers
1997-2006 Expedition & Navigator
05-27-2011 09:09 AM
SHOpar
13
04-29-2011 11:24 PM
coltabsh
16
01-19-2011 12:35 PM
Quick Reply: A/C and Advance Trac Problems
