Ex won't start
Old Aug 17, 2009 | 09:31 PM
BroncoDoug's Avatar
BroncoDoug
Ex won't start
I turned off my V10 Excursion after driving it for a couple of miles and when I went to restart it; it ran really rough for a couple of seconds until it completly died. It would not catch after that. I sprayed starting fluid into the throttle body and it would run for a few seconds until it burned the fluid up. I checked all the fuses/relays and I did not find any issues. I want to make sure I did not overlook anything prior to replacing the fuel pump which will cost a couple of hundred dollars. Any suggestions?
Old Aug 17, 2009 | 10:38 PM
Monsta's Avatar
Monsta
Sit. Stay.
Can you hear the pump prime when you turn the key to the ON (but not Start) position?
Old Aug 17, 2009 | 11:01 PM
BroncoDoug's Avatar
BroncoDoug
I have not been able to hear the pump.
Old Aug 18, 2009 | 12:00 AM
wallz's Avatar
wallz
Welcome to the FTE family!
Have you tried hitting the tank from underneath. Sometimes that gets er going, and atleast you can say it the pump before replacing.
