2011 Super Duty spy shots!!!
#46
on
Why fix what aint broke? Isn't that how Ford got in trouble with the 6.0?
As for all those that complain about the aging cab, think about how long Ford used the same cabs on the previous gen F-series before the 97 F150 and 99 Superduty...
I can tell you this though, Ford needs to step it up in the paint quality department. I have paint flaking and rust on my 05 but not my 01, something changed in 4 years, and not for the better...
#47
#48
#49
I hear you on that paint though, god. My mom's '99 Cougar has great paint on it, but my '03 Focus was spotty underneath the clear.
#50
The reason for the larger hood design is to fit the new 6.7L and tranny under it. It is much bigger than the previous Power Strokes. It will be a Ford built diesel kinda on the Navistar 7.3L platform. It will be a beast and lots of tourq right off the showroom floor. Also it will have a Urea tank and pump to "scrub" the nitrogen oxide from the exhaust....thanks EPA!(oh brother). Any way the good thing is the Urea will not hinder power like the other scrubber used now.
#52
#53
#54
5 firings per revolution versus 4 makes for a higher "average" torque. 462ft/lbs (what the 3-valve V10 puts out) with 415 cubes, while the 6.2 is only 378 cubes or so. It will be interesting to compare the two, that's for sure.
#55
They will be hard pressed to generate more torque from 8 cylinders than from 10 cylinders, with less displacement.
#56
#59
X2 on the paint flaking. I wash my truck almost weekly, under carriage too, and the paint blows. I use ICE wax 3 times a year, and I usually clean it with clay to get the impurities out.... But the paint chips off the edges so easy. WTF.... Its paint, shouldn't skimp!!!
#60
