Bronco II Ford Bronco II
smoking blue
Old Aug 16, 2009 | 10:37 PM
tn terry t's Avatar
tn terry t
smoking blue
88 b2 installed reman longblock from Grooms last year maybe 10,000 miles it. the thing started smoking blue oil smoke shut it off for bout 10 mins. fire i back up ,no smoke run bout 2 mins it smokes real lite and steadly gets worse. if it was an older engine i would say the valve guide seals had failed and was stopping the oil returns what you guys say?
Old Aug 17, 2009 | 01:24 AM
Jab'sBronco2's Avatar
Jab'sBronco2
do a compression test.
Rings / valve guides are most likely shot already.
when you got this reman longblock did it come with the new fab heads? or the old style pos heads?
Update us!
Old Aug 17, 2009 | 05:18 AM
tn terry t's Avatar
tn terry t
it has the new fab heads. Rings / valve guides are most likely shot already? with 10,000 miles? wow! i sure hope not.
thanks for the reply
Old Aug 19, 2009 | 09:34 PM
rebocardo's Avatar
rebocardo
This is where a leak down test comes in handy.
Old Aug 20, 2009 | 05:33 AM
tn terry t's Avatar
tn terry t
i hate to ask but what are you talking about as to the leak down test ?
my brain ain't working so good right now
Old Aug 20, 2009 | 11:46 PM
rebocardo's Avatar
rebocardo
It is like a compression test, but, you use an air compressor to feed air into the cyl., then you see where it leaks out.
